Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Best 'free' mods on mach
Old 03-29-2009, 03:41 PM
nikbait
nikbait's Avatar
Default Best 'free' mods on mach
Does anyone here have like a list of the best 'free' mods you can do to the machs?
nikbait is offline
Old 03-29-2009, 08:59 PM
BRIAN67SHELBY
BRIAN67SHELBY's Avatar
I believe I read somewhere that you can actually raise the hood scoop higher, but I would be carefull because you wouldn't want it too high thus causing damage to your hood/mounting bracket at high speeds. Not really sure if it will help with more air going towards the filter.
BRIAN67SHELBY is offline
Old 03-29-2009, 09:31 PM
nikbait
nikbait's Avatar
I've not heard anything about raising the 'hood scoop'. The machs only have the shakers. I've raised my shaker with some washers, and that's about it
nikbait is offline
Old 03-30-2009, 02:58 AM
BRIAN67SHELBY
Yep, the shaker. That's what I meant to say.
Old 03-30-2009, 09:46 AM
nikbait
nikbait's Avatar
hehe thats ok
nikbait is offline
Old 03-30-2009, 03:03 PM
TubbaMach
TubbaMach's Avatar
I knew what Brian was talking about, give him a break Mach MAMA! HAHA
TubbaMach is offline
Old 03-31-2009, 12:04 PM
nikbait
nikbait's Avatar
lol that's ok.
nikbait is offline
Old 03-31-2009, 04:24 PM
BRIAN67SHELBY
Also, if you haven't already done so, the snorkel can be removed from your air filter housing.
-The factory screen in the stock Mass Air Meter can be removed to allow a better flow(do this at your own risk though).
-The factory Throttle cable is way too long and you can add a spacer to take up the space or (I know this isn't free) pay 3.00 to get a throttle cable adapter and bolt it to the cable to take up slack. This usually requires to snip the very end of the cable ( the stock crimped piece). I would suggest soldering to prevent unraveling of the cable prior to installing the throttle stop. You will notice a lot better acceleration at WOT. In doing this, it is possible to take up so much slack that you will bottom out at the TB. This will result in a possible stretched cable or bending the sheet metal of the gas petal assy. I do see some racers weld a nut and bolt (to adjust the max petal travel) to the floor just underneath the gas petal to prevent this. You know how some of these mustang guys like to slam on the gas.
The only other free performance mod is reducing weight. It just depends on how you want your car to look and what you're comfortable about removing without having the inside look like a nascar race car( showing all sheetmetal).
1BAD3V
Tennessee Regional Chapter
10-06-2016 12:12 PM
baddog671
07-26-2016 01:20 PM
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
PaulH2
20
01-31-2016 09:48 AM
1BAD3V
Indiana Regional Section
09-26-2015 09:03 AM
Quick Reply: Best 'free' mods on mach
