superchargers for mach1
ok at the risk of sounding like a giant doucher....
is there a supercharger for the mach1 that will keep the shaker hood functional? i saw this http://www.mustangmonthly.com/featur...bra/index.html but dont know if it was logical. im not rich so money eventually become a problem... i did see that saleen came out with a "supershaker" for the s197's but would it work on a real mach???
Vortech makes a system that keeps the shaker functional. You end up paying about $5k for the supercharger, then another $600 for the duct work for the shaker.
http://www.vortechsuperchargers.com/product.php?p=92
Hmm, I wonder if there would be any benefit to running custom air-tight intake piping from the scoop to the filter/maf on an n/a setup. And make the air filter completely contained in the piping. It would definitely make a nice woosh sound from the top of the hood , but would it be more restrictive and do more harm than good?
if only ford could have done a speed density system for this car to make it a direct shaker to the top of the manifold like a T/B in the base of the shaker underneath a filter all on top of a high rise intake manifold.
That's a good point about the water, I guess you would have to incorporate some sort of drain but then that would allow air in elsewhere. What do you think about the power gain potential? Is there any possible advantage to having an air-tight intake from the scoop?
I was looking at the vortech kits today on superchargers online, and it says the reason they dont have the kits to keep the hood functional is because its for looks more than performance.
However; they do say that they are working on a kit that will keep the shaker functional.
The shaker scoop only truly works at speeds (estimating) above 60mph where air is being rammed into it and the intake is actually creating enough vacuum for air to be chosen to flow that way. the shaker i feel does help somewhat, still ford could have came up with a better system for it to make it truly a functioning piece for performance, but they did what they did to save money and time for production reasons.
I do believe an airtight box would work in your terms as long as the air came in from the bottom of the box and went up through the filter this i suppose would eliminate the water problem. a small hole for drainage wouldnt hurt i suppose but who knows, with an airtight box it may try to suck air through that hole eliminating the purpose of that drain hole (if the engine drew enough vacuum)
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
