eaton swap questions?
This is a start...I have a thread on my build on the 2nd page of this section.
• Supercharger with stock pulley
• Lower intake
• Intercooler
• Water manifold with nipples
• Throttle body with plenum
• 39 lb. injectors
• Vacuum actuator w/attaching hardware
• EGR valve – new straight plug IAC – w/attaching hardware
• EGR sensor bracket
• EGR riser tube
• Accelerator cable with bracket and attaching hardware
• MAF housing
• IAT 2 / BARO sensor w/ attaching hardware
• Timing chain cover - new
• Cross tube w/sender
• Main pulley bridge w/tensioner and idlers
• Alternator idler bracket
• Used alternator
• Both alternator to block bracket
• Harmonic balancer
• Lower caged charger pulley with idler
• Intercooler pump with bracket
• Intercooler reservoir
• Heat exchanger lines
• Hard intercooler line at block
• Heat exchanger brackets
• Heat exchanger
• Long heat exchanger lines
• Heat exchanger engine hard lines and hoses
• P/S bracket
• Belt engine cover
• Air intake to MAF housing
• Long upper cross tube hose
• Upper radiator hose
• Blower belt
• Accessory belt
• Lower intake
• Intercooler
• 39 lb. injectors
• EGR riser tube
• MAF housing
• Used alternator
• Harmonic balancer
• Heat exchanger
• P/S bracket
• Belt engine cover
• Blower belt
• Accessory belt
jaiidutch
09-14-2015 10:29 AM
