Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
My Eaton Swap Project Using Custom Brackets
Old 03-22-2010, 08:04 AM
Furinox
Furinox's Avatar
The car made it's maiden voyage this morning to work. No leaks or anything so thats good. Just gotta work on the tune now. It's running a bit rich with 15% fuel added. I gotta play with the tip in and lean it back out some.
Furinox is offline
Old 03-22-2010, 09:06 AM
YellowMACH04
YellowMACH04's Avatar
The car looks amazing!! How does doing an Eaton swap compare to doing a Kenne Bell kit as far as power on stock bottom end, power potential later on, reliability, and cost?
YellowMACH04 is offline
Old 03-22-2010, 11:40 AM
Furinox
Furinox's Avatar
Cost is definitely a lot less. I'd say its more reliable as well since there are rarely failures with these blowers since they are an oem part. The most you can get out of an eaton is a little over 500RWHP. Its very easy to make over 400 with an eaton swap which is all you would want on a stock block car.
Furinox is offline
Old 03-30-2010, 09:54 PM
Furinox
Furinox's Avatar
More pictures
Furinox is offline
Old 03-30-2010, 10:01 PM
hpwrestler220
hpwrestler220's Avatar
Awesome man.. Absolutely awesome.. And the blower almost looks hidden below the shaker. That's pretty shnazzy
hpwrestler220 is offline
Old 03-30-2010, 10:32 PM
lazyeye
lazyeye's Avatar
i came
and then i came again!
lazyeye is offline
Old 03-31-2010, 08:26 AM
darkmach1
darkmach1's Avatar
What coolant are you using? Just wondering.
darkmach1 is offline
Old 03-31-2010, 02:20 PM
Furinox
Furinox's Avatar
I just used generic coolant from autozone and then did about a 70% water/ 30% coolant mix.
Furinox is offline
Old 04-12-2010, 10:50 AM
Furinox
Furinox's Avatar
Went up and stuck it on the dyno. Surprisingly the tune I made was almost dead on. Just had to add about 4% fuel on the top end. Made 440hp/460tq with 14* of timing. Going from 12 to 14* of timing the car picked up 30rwhp. Car has a pretty good miss after messing with it and I really havent been happy with these TR6 plugs. Going to put BR7EF's back in it and add more timing and I should be close to 500 rwhp.
Furinox is offline
Old 04-12-2010, 11:06 AM
USMCrebel
Mach I Section Moderator
USMCrebel's Avatar
whats the specs on your motor again?
USMCrebel is offline
Quick Reply: My Eaton Swap Project Using Custom Brackets
