Few supercharger ?'s
#22
#23
while i love the KB sound and performance, the price is a huge deterrant. a P1sc or a Big Pulley D1sc will do more than you ever need. oh and the motor is not lacking in lowend torque...
#24
#25
No it doesn't...
FWIW the high compression isn't the issue here, its the crap castic things attached to the forged steel goodness (ie the rods and pistons)...there is a guy running 6.40's @213 running a 4.6 mod motor with 11.25:1 compression. if you had forged guts i would keep the 10:1 motor ensure plenty of fuel got to the pistons and have as little quench as possible to ensure a complete burn. i guess you could run ~10psi-12psi on pump any higher i would run some race fuel. or you could go the way of the cobra and have an 8.8:1 ( i think) and slap some TT's on it and have equal fun.
#26
Actually the Terminators have 8.5:1 compression due to their dished pistons. I have the same compression ratio on my Aluminator, because it has the same pistons as the Cobra, duh. LOL! Granted, if the CR was a bit higher, I could be cranking out closer to 600rwhp without making any other changes. But, by the same token, I can safely run higher boost levels than most, plus if I want to get really squirrely, I can put my 100 shot of nitrous back on this sucker without having to worry about the added pressures. I think somewhere around 9.5:1 would be just about perfect for a blower motor.
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
