Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
weird sound coming from transmission? need help
Old 07-12-2010, 01:44 AM
RickyD53
RickyD53's Avatar
Default weird sound coming from transmission? need help
i have a manual 2004 mach 1 with 23,xxx miles. and when i start the car, while it idles you can hear a sort of shaking sound or like tick sound in a way and when i barely push on the clutch, the sound stops and i release it, it comes back. but if i drive the car around the sound will stop but will come back when i stop the car and start the engine again. what can this be from? is it normal?
RickyD53 is offline
Old 07-13-2010, 01:15 AM
Fstanggt96
Fstanggt96's Avatar
That is your throw-out bearing, mine does the same exact thing and I am replacing the clutch soon. Mine has 53k miles.
Fstanggt96 is offline
Old 07-13-2010, 02:16 AM
RickyD53
RickyD53's Avatar
But if it was a throwout bearing, wouldn't you hear it from the stick? I only hear mine on the outside of the car.
RickyD53 is offline
Old 07-14-2010, 12:53 PM
RickyD53
RickyD53's Avatar
and to clarify, the sound is more like a tick tick tick.
RickyD53 is offline
Old 07-14-2010, 05:43 PM
.boB
.boB's Avatar
Most likely the TO bearing. That's common and normal. That's why the stock pedal has an automatic adjuster on it. The design is to keep a little bit of pressure on the bearing all the time. Not enough to call it pre-load, but just enough to maintain solid contact. It was part of the noise reduction required by the EPA.
.boB is offline
drfister
05-03-2018 10:38 PM
KinneyD
01-09-2016 05:33 PM
antipeterleague
08-18-2015 01:50 PM
gagemcc
08-17-2015 10:30 AM
yurizx6r
08-11-2015 07:50 AM
Quick Reply: weird sound coming from transmission? need help
