A newb from GB
A newb from GB
Hey guys just thought I'd drop in and introduce myself. My name is Jim and I'm from Glen Burnie and I have a 96 Stang with a 4.6 that I've put Fox Lake cnc ported heads, Typhoon Intake, 102700 CompCams, Trick Flow upper plenum, BBK adjustable fuel pressure regulator, Aeromotive fuel rails, Ford Motorsport 24lb injectors, BBK long tubes with a no cat X pipe and flowmasters, Maximum Motorsports full tubular front end and camber adjusters, KYB AGX shocks with Coil overs on all 4 corners, MSD DIS4 Ignition, Canton windage tray and 7qt pan, Aluminum driveshaft and flywheel along with a bunch of other little odds and ends. I also have a fresh block sitting in my garage that I'm trying to get the stuff together to do a stroker.
