OFF-ROAD Mid pipes in MA
For those of you that have the off-road midpipes, how are you able to pass inspection in MA? Do you take out your midpipe and replace it with the catted mid-pipe just for the inspection and replace it back to the off-road pipe after you had your car inspected?? Or do you go to a place that dont check??
It depends on the year. For you new edge guys the MIL's are a great choice. Second after that would be the non-fouler trick.
I drove straight from Pete's to an inspection bay (61 miles) and passed no problem without cats.
Even still, if the inspector is a jackass you can still get failed, but thats obvious.
I'm late on this, but they will prob do a sniffer test, if they do then no MIL will make you pass. In which case you need cats to pass a sniffer. If you are only doing safety, then you can not have a CEL on or they will fail you right off the bat.
I thought I remembered that about them changing it but wasn't sure. in that case get MIL's and as long as the place isn't a d!ck and your car doesn't smell up the place then you should be good.
