The Unicorn
The Unicorn
https://cimg7.ibsrv.net/gimg/mustang...d19d5dd4ad.jpg 2017 F150 5.0 (Gen 2) - JE pistons (12.5:1 compression) - 2018 Mustang GT intake (ported) - FAST 87MM throttle body - Lokar throttle cable - L&M intake camshafts - Gen 2 Mustang exhaust camshafts - ARP cam tower bolts - ARP cam phaser bolts - ARP harmonic balancer bolt - MMR tensioner chain flip bracket - Mustang timing cover - PBH AC compressor bracket - IW harmonic balancer - S550 200A alternator - S550 oil filter adaptor - MMR rear coolant crossover - Boundary Billet oil pump gears - Boundary Billet crank gear - MMR piston cooling jet delete Holley HP EFI standalone - Holley TiVCT controller Flex Fuel system Aeromotive AFPR QFS 340 pump in Pro-M hanger 6AN feed/return PTFE stainless braided fuel lines 10 micron filter 47# injectors Continental Flex fuel sensor Powerhouse Racing billet flow through adapter Exhaust BBK 1 3/4" long tube headers BBK X-pipe Dynomax UltraFlo mufflers Flowmaster Foxbody LX tail pipes SLP exhaust tips Drivetrain: T56 Magnum - QuickTime bellhousing - Exedy Twin Disc clutch - Stiffler's T56 crossmember - Driveshaft Shop aluminum shaft 8.8 rear - Eaton Truetrac - Yukon 31 spline axles - Strange C-Clip eliminators - 4.10 gears - LPW Ultimate differential cover Suspension: Maximum Motorsports tubular K member 94/95 Cobra front sway bar MM sway bar relocation MM sway bar bushings MM lowered end links MM forward offset control arms MM caster/camber plates MM MM3 struts (race) MM RA2 shocks (sport) MM coil overs (425/325) MM subframe connectors MM road race control arms MM rear adjustable sway bar MM panhard bar MM heavy duty torque arm MM Race shock mounts Brakes, wheels and tires: 18x9/18x10 Forgestar F14 275/35/18 Federal 595 RS-Pro Brembo 44/40 calipers with Autology brackets 14” GT500 rotors Powerstop red powder coated rear calipers 13” Baer Eradispeed +1 rear rotor kit Powerstop Trackday pads Stiffler’s stainless brake hoses Fine Lines stainless brake lines ABS delete block Interior: 1998 GT interior (RIP Space Ghost) Mach 1 door panels [thank you, Matt [url=https://www.sn95forums.com/members/8290/]@uncltrvlnmatt ] 99-04 Console dual USB charging port 2000 Cobra R style shift knob leather wrapped Momo Corse steering wheel NRG short hub NRG gen 2 quick release Corbeau Forza Sport drivers seat for autocross days Black 2005 GT seats for street use billet Unicorn head light knob rear seat delete Holley 7" digital dash Holley LED shift light Holley GPS Steinmann Performance cluster dual gauge panel with dual USB connections for Holley ECU/Dash Autometer Cobalt programmable fuel gauge Innovate DLG-1 wideband gauge Alpine CD player Boston Acoustic 6x9’s (doors) Rockford Fosgate 6x8’s (deck) Exterior: 1997 Cobra hood Aerocatch latches vertical, export tail lights [very bright, LED bulbs] Madd Retros projector headlights 4300k HIDs (meh) Saleen front bumper Carbon Fiber T1 wing _slib's flared Carbon fiber fenders Misc Volvo electric power steering pump Converted to hydroboost brakes Converted power steering hoses to AN hoses 2000 Cobra R steering rack C6 fan controller Champion 3 core radiator Parts pending installation: Cortex Watts link Kenny Brown adjustable front sway bar MM roll bar Thanks for reading, there is much more to come - Josef |
Custom cold air that will be installed very soon:
http://i33.photobucket.com/albums/d7...pscc573f41.jpg Fox style throttle body swap: http://i33.photobucket.com/albums/d7...psa182856f.jpg Hope to have the final tune soon and more updates!! I have a IRS swap, custom side exhaust, lots of engine bay detailing, more suspension and brake upgrades to perform!! |
lot of work you did there.
Update!
Well, I forgot all about this thread!! A few things have changed since 2013. I updated the first post with a very recent picture, current mod/project list. Sold off all of my IRS stuff and bought a Watts link from my good buddy Pete @ Fully Torqued Racing. I had the heads CNC ported, the valvetrain rebuilt to match the cam, changed the intake out, swapped to long tubes and a few other bits.
I'll try to update this more often LOL |
