Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
91 crown vic 5.0 into a 95 mustang V-6?
Old 07-25-2012, 09:16 PM
hotrodb
hotrodb's Avatar
Default 91 crown vic 5.0 into a 95 mustang V-6?
I'm looking to put a low mileage 5.0 from a 1991 crown vic into a 1995 Mustang V-6 car. Some of my questions are; Will the crown vic wire harness and computers bolt up to the must. and work without modifying them? Basically if I have the entire crown vic can it be a plug n play swap? Is the 95 must. key chipped to the fac. comp? Any help will be much appreciated!
hotrodb is offline
Old 07-27-2012, 11:17 PM
hotrodb
hotrodb's Avatar
Would it be easier to just run a carb in the 95'...???
hotrodb is offline
Old 07-28-2012, 10:49 AM
NYstang
MF Staff Snitch
NYstang's Avatar
Crown vic is a speed density car, as well as a lopo engine. That means different pistons, heads, intake, firing order, and thus cam. While you would be gaining torque, you would have the same power, and take a good bit of work put it to GT specs. the pistons have no valve reliefs, so you can fit a stock HO cam in it, but any more you need new pitsons (IIRC, its been a couple years).
NYstang is offline
Old 07-29-2012, 10:46 PM
hotrodb
hotrodb's Avatar
Thanks for the info...I am doing a father-son's project with my kids 95 Must. I wonder if it's hard to run a carb. in that body? And does that apply to the 5.0 in my 99 explorer with Gt-40P heads?
hotrodb is offline
Old 07-29-2012, 10:48 PM
hotrodb
hotrodb's Avatar
I mean as far as pistons go and cams?
hotrodb is offline
Old 08-01-2012, 09:51 PM
hotrodb
hotrodb's Avatar
Ok so I believe I have everything worked out for the swap. Next step is gathering the parts then building the eng. & trans. installation will follow shortly there after...Thanks for the info NYstang!
hotrodb is offline
MusBBad95
08-17-2015 09:39 PM
Jacob4589
08-17-2015 09:34 PM
Soldier GT
08-12-2015 03:46 PM
05slpGT
08-12-2015 02:32 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: 91 crown vic 5.0 into a 95 mustang V-6?
