1999 Base Coupe 3.8 -> To 5.0L V8
I bought a 1999 body which was swapped to a 5.0L V8 I hade the original A9L computer which of course came with the V8 that was pulled from a 1992 Fox Body. I "accidentally" through away the original A9L ECU and now I'm shopping around and researching for alternate PCMs or engine control modules that would work, and by work I mean won't cause problems even if it's at the expense of power.
2. I'd also like to ask how would I go about adding and aftermarket set of gauges that work? Speedometer etc etc I want to totally switch out the instrument cluster. I'm also not concerned about emissions as bad as that sounds. |
It still has the six cylinder dif?
Originally Posted by Camster
(Post 8554746)
