So the block and heads from a 2002 Town Car is the same as a 2002 GT? Need a motor for my 2002 and if they are the same block and heads I will pick one up this week. Same internals? Part numbers are different but that usually doesn't mean anything.
Originally Posted by JC316
Yes. I've done it several times. Some stuff might have to be swapped over, motor mounts and what not, but the engines are the same.
Yup. Retain the exhaust manifolds, flywheel (if manual trans), throttle body/plenum (CrownVic/Towncar are facing the opposite direction), maybe a couple other little things from your existing engine and install on the replacement. But aside from minor external differences like mentioned above the '01+ CrownVic motors are exactly the same as ours.
