swap from 98-4v to 2v reason explained in post
I have a chance to buy a 98 cobra. The piston came out the side of block and broke the engine and part of the head.
Finding a cheap replacement engine dont seem like a easy task. I am aware of some of the other cars I could take from to make a stockish swap happen.
What i want to know is if I had say a 2000 Crown Vic with a new engine setting in it from a police sale, how much trouble is it to change out the 4V to a much easier to find 2V?
I have seen it done the other way.. But if someone has a good link to a detailed install that way or this I could not find one that I would feel comfortable in what it said.
never heard that tha blocks where interchangeable.
I know that cobra has a aluminum block but I dont really care if I have to use a iron block as a replacement. Short blocks are easy to find cheap too.
ANY idea on which blocks would work better and info on any problems I would have to address?
I have installed a Mark 8 block in a 98 cobra in the past. It was rather easy as most parts just swapped over from the blown cobra engine to Mk8.. intake and such.. Oil pan and pick up.. and knock sensors. I had to order a new 6 bolt fly wheel as my 8 bolt did not work.. But reused the same clutch and pressure plate.
If you decide to move forward with a 2V, my only advice is that you pick from a 2001 or newer CrownVic/Towncar. They used the PI top end found on the '99+ Mustangs.
Also, I would stay away from anything out of a police or taxi service vehicle. Going to have very high mileage and a service life that would fall under the "severe use" end of the spectrum.
yeah I going to try and keep it 4V as that would be a drop in and go kind of deal.
Still the question of which block to use.
I have a local police force that is selling all the CVs they have.. MOST of them had new engines put in with less than 10k miles. they also selling complete engines that are crate motors they bought just to keep the cars going.. They have like 10 of those.
They keeping till they rotate all the CV out of service and get enough of the caprice and ford tauraus and some of those dodge things to have enough back up cars.
Yes. I've done it several times. Some stuff might have to be swapped over, motor mounts and what not, but the engines are the same.
