08 V6 to 4 Valve Swap Questions
Im swapping out a Factory 4.0 V6 from my 08 Pony to a '94 281 4 Valve its got the teskid block and everything of course, and have some questions, im getting all stuff required together before I ever pull a bolt. So far I have the Fresh built 4V, a Cobra Upper and Lower intake, found me some cobra exhaust cams, and an 8.8 rear end im planning on 3.73's. Trans at this point is just a T45(Temporary) still thinking about what exhaust, Long tubes most likely, and I have a Ron Francis conversion harness on order now for the swap. My questions are what do I need for ignition for the swap? Also what do I need to make to the fuel system work? Ive think the 6er is factory returnless fuel system not completely sure tho im assuming fuel pump, rail, injectors. and lines?
Inspector Todd
06-29-2006 11:58 AM
