s197 v6 -> swap v8 4v cobra supercharger -> what ecu to use ? - MustangForums.com
Go Back  MustangForums.com > Ford Mustang Tech > Motor Swap Section
Reload this Page >
Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
Old 10-10-2018, 08:16 AM
Nikita_str77
Exclamation s197 v6 -> swap v8 4v cobra supercharger -> what ecu to use ?
Hey guys, Greetings from Moscow! I have an idead to swap my v6 pony into 4.6 Mustang GT. Reading alot, i bought iron 4.6 v8 with AODE/4r70w transmission.
Also i bought 4v heads and eaton m112 supercharger from cobra 2003.
And now, before buying lower intake and intercooler, i got a question.
What ECU to use? If i use sn95 ECU they won't connect with other modules on s197 ?
Can i retune 3v s197 ECU and re-make wirings to use with Cobra engine? Or just buying sport ECU like AEM or LINK G+ ?
If it's not possible, i have to sell it and buy 4.6 GT 3v. Thanks.
Nikita_str77 is offline
Old 10-10-2018, 08:18 AM
Nikita_str77
Old 10-10-2018, 02:06 PM
08'MustangDude
You can't use the V6 ECU on the V8 motor, that is for sure.
Not sure which V8 ECU to use either, but you can'y use the V8 one.
08'MustangDude is offline
Old 10-10-2018, 02:19 PM
Nikita_str77
PCM from s197 v8 or from sn95 ? will pcm from sn95 fit with ecu of 2005 s197 ?
Old 10-10-2018, 03:55 PM
08'MustangDude
If you have the SN97, you're in the wrong section, and you're subject and message detail
are all over the place.
Subject: s197 v6 -> swap v8 4v cobra supercharger -> what ecu to use ?
Then you say: I have an idead to swap my v6 pony into 4.6 Mustang GT.
Then it looks like you want to take a V8 Cobra motor from an SN97, and put it into an S197.
You will need this ECU and Engine harness, and transmission, but I don't know why you
just didn't get a 05-10 4.6 or even a 5.0 Coyote.
You will have to have the ECU tuned for the SuperCharger no matter what you do.
You need the 4.6 V8 ECU, preferably from the donor motor, and the harness, because
the transmission bolts to that SN97 V8 motor. The Automatic S197s all use the 5R55S.
Please take some time, and explain what it is, exactly, you want to do, because you have
two different ideas going there.
Old 10-11-2018, 02:17 AM
Nikita_str77
Okey, i will try to explain.) I m from Russia and it's the main problem to find any parts here. On our backyards, we can find only old 4.6 Romeo or from Lincoln Aviator.
The main idea of it is to build supercharger 32v cobra engine into s197. I was searching via stang forums in US and found out that there are lot of s197 with 4r70. But it's not problem i have one 5R55s from v8 GT s197.
I just want to understand if i install 32v cobra i need to use PCM(ECU) from s197 4.6 GT and tune it? Or i have to buy ECU AEM / G4+ to connect it with can-bus ?
Old 10-11-2018, 05:09 AM
08'MustangDude
Any supercharger addition needs a tune, the car won't run under boost without it.
You need the ECU for that motor, and the trans, since the ECU also shifts it.
Old 10-11-2018, 01:00 PM
Nikita_str77
I know about tune.
I just want to know, if i want working cluster and other from my stock car, i have to use s197 PCM ? or if i use cobra PCM it will works too ?
sn95.4V
02-15-2018 10:05 PM
5.0stanger
Want To Buy Ads
08-05-2012 11:14 PM
NeoTokyo
05-25-2009 12:59 PM
NeoTokyo
05-25-2009 05:59 AM
UndergroundMustang
09-05-2006 05:56 AM
Quick Reply: s197 v6 -> swap v8 4v cobra supercharger -> what ecu to use ?
Featured Sponsors
