Motor Swap Section Tech and Follow-My-Build Threads for members looking to put a different engine in their Mustang
07 4.0 Mustang Motor Swap
Old 04-15-2019, 06:59 PM
Rockstangta1st
Default 07 4.0 Mustang Motor Swap
Hey guys,
This is the first time I have ever even used a forum but I have a problem that my dad and I just can't figure out. normally when you pull a motor out, There are bolts that you have to undo not only from the transmission but also the torque converter. that being said there normally a plate at the bottom of the transmission that enables you to (while someone is cranking the motor for you to reach all the bolts) remove all of the bolts from the torque converter through the little "peep hole" however my mustang does not have the plate to enable me to do that. So my question is, how do I go about removing the engine from the Transmission?
Any help is welcome. Thanks.
Rockstangta1st is offline
Old 04-15-2019, 07:16 PM
Rockstangta1st
Also, Very important that I forgot. My Mustang is a 2007 V6 4.0. all I'm doing is pulling the motor out.
Old 04-15-2019, 07:29 PM
Rockstangta1st
Old 04-15-2019, 07:31 PM
Rockstangta1st
and unfortunately I'm awful with this and commented the same thing twice. My bad.
Old 04-15-2019, 10:56 PM
imp
imp's Avatar
Turn the crankshaft using a socket inserted into the front "snout" of the shaft, where the harmonic balancer is. Be careful not to damage the crankshaft position sensor there which "looks" at a toothed wheel.
imp is offline
Old 04-16-2019, 04:12 AM
Rockstangta1st
I would love to say mine is not broke but there is a connecting rod that blew so I feel the need to pull it out to fix it. But thank you! that actually helps a lot.
sailorflavor
08-17-2011 05:04 PM
rik_0_1
08-16-2010 09:46 AM
Project 5.GO!
01-29-2009 05:09 PM
sickspeedgt
04-26-2005 03:58 AM
slegos888
12-15-2004 01:35 PM
Quick Reply: 07 4.0 Mustang Motor Swap
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
