428 scj rebuild
[align=left]I'm currently in the process of rebuilding my 428 SCJ engine and have several questions, which I hope you can possibly help me with.
(1) Cylinder heads- the heads are C8OE-6090-N Do these heads use spring cups and or spring seats? (2) In our move from Pa to Fl several engine items were lost and need to be replaced. -Fuel Pump Eccentric with cam bolt and washer -Cam thrust plate and retaining screws and lock washers -Crankshaft oil slinger -Baffle oil galley (I have the cast iron manifold) -Back of the block plate between the block and the bellhousing -Oil filter adaptor C8AE-6881-A -Where can I get these parts and if you know the part# and the cost. - I plan on a new hydraulic camshaft and to use the 1.76 ratio adjustable rocker arms.This will be a street application. I would appreciate a cam recommendation and the pushrod length for this application. -P.S.-when using the B8A6564B Adjustible rocker arms do you still use the B8AZ6563D Hydraulic rocker shafts, and where can I get 2 new ones and at what cost? -What would be the preferred method for valve adjustment? Any and all help would be appreciated. After this rebuild I will be back and request your help in finding a car. Thank You JPM [/align] |
