8.8 SVT Rear Axle
Old 10-29-2012, 02:34 PM
Jarrod@latemodel
Former Sponsor
Jarrod@latemodel's Avatar
Welcome to the forums. Like others have said the stock 8.8 on your 09 is plenty of strong for now. They are built from the factory with 31 spline axles. I made about the same power you did with my 06 and never had any problems with it. It had over 100 passes on it, and 108,xxx miles when I sold it.
Jarrod@latemodel is offline
Old 10-30-2012, 12:06 PM
stangthang13
stangthang13's Avatar
well what if i said it looked like fluid was leaking...not a lot you can just tell that the differential has a wet look on it. would you guys then suggest the 8.8 SVT one?
stangthang13 is offline
Old 10-31-2012, 09:43 AM
Jarrod@latemodel
Former Sponsor
The rear end is the same for the most part. Your only real difference is the GT500 heavy duty pinion bearing. Its still the same 31 spline axles, seals and everything else. If you want a stronger rear end, it can be built for much cheaper.
So IMO I would say no, there is no need to buy a new rear end assembly just because it says its an SVT. You would spend a lot more money that away.
Old 10-31-2012, 12:12 PM
stangthang13
Alrighty. So you think the stock one will last even if I do some more power upgrading? And lets say it does blow, would you suggest a 9in moser and build on it?
Old 10-31-2012, 12:38 PM
2007StangV6
2007StangV6's Avatar
How much more power are you looking to make?
The 8.8" is pretty strong. If you're that worried about it, just buy the rebuild kit and rebuild the one you have since you say it's leaking.
2007StangV6 is offline
Old 10-31-2012, 12:47 PM
Jarrod@latemodel
Former Sponsor
No need for a 9" unless you plan on back halfing the car and making 1600+ hp. There are guys running around with north of 600 hp and not having any problems.
Like I said, I made around the 480 mark with my 06 and never had any problems from the rear end.
Old 10-31-2012, 12:54 PM
95 BLOWN GT
95 BLOWN GT's Avatar
welcome..
95 BLOWN GT is offline
Old 10-31-2012, 01:10 PM
stangthang13
Okay thanks for the help. I was just thinking 9in cuz those things are indestructible.
Old 11-01-2012, 09:53 AM
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
welcome to the forum!
mygt500 is offline
11-10-2015 11:39 AM
67LimeCoupe
09-30-2015 04:46 PM
PB Pod
Forum Issues and Feedback
09-17-2015 08:32 PM
09-10-2015 08:39 PM
Dragonus18
09-09-2015 01:21 AM
Quick Reply: 8.8 SVT Rear Axle
