2008 mustang 4.0 A/C issue
Hey guys i have this problem that drove me insane , i have this 2008 mustang 4.0 it was auto then I swapped it to manual so before the swap ac works fine and after the swap ac works fine as well then for about 2-3 months having ac it suddenly stopped working , i replaced AC compressor, evap coil , condenser, ac dryer , both sensors for high and low, and ac Orific filter but nothing seems to work im not getting any sort of ground into ac so i wired straight from ac button to the ac relay then i did get it to work but the ac turn on then after 30 seconds the pressure gose high so i blew the new compressor then i got another one and i flushed the hole system then replaced it again but i still get the same results it gose to green then build up to red and it started by the car struggling when ac is on sometimes it turns off when i come to a complete stop dose anyone have any idea please? Thank you
[QUOTE=khaleel;8719877]Hey guys i have this problem that drove me insane , i have this 2008 mustang 4.0 it was auto then I swapped it to manual so before the swap ac works fine and after the swap ac works fine as well then for about 2-3 months having ac it suddenly stopped working , i replaced AC compressor, evap coil , condenser, ac dryer , both sensors for high and low, and ac Orific filter but nothing seems to work im not getting any sort of ground into ac so i wired straight from ac button to the ac relay then i did get it to work but the ac turn on then after 30 seconds the pressure gose high so i blew the new compressor it literally leaked all freon front the side of the compressor then i got another one and i flushed the hole system then replaced it again but i still get the same results it gose to green then build up to red and it started by the car struggling when ac is on sometimes it turns off when i come to a complete stop dose anyone have any idea please? Thank you
