Hemi Valve Seat Drop Issue Petition - MustangForums.com
Old 05-17-2018, 10:55 AM   #1
ZEN357
ZEN357's Avatar
Default Hemi Valve Seat Drop Issue Petition
Hello,
I just signed the petition, “Chrysler Group Customer Care: Dodge: Recall the motors with the dropping valve seat issues.” I think this is important. Will you sign it too?
Here’s the link:
https://www.change.org/p/chrysler-group-customer-care-dodge-recall-the-motors-with-the-dropping-valve-seat-issues?utm_medium=email&utm_source=petition_signer _receipt&utm_campaign=triggered&share_context=sign ature_receipt&recruiter=875151742
ZEN357 is offline   Reply With Quote
Old 05-18-2018, 07:52 PM   #2
TRamsdell
IN JAIL!
TRamsdell's Avatar
This is Stoopid. Sign the more holes with more power into a Miata petition.
TRamsdell is offline   Reply With Quote
Old 05-19-2018, 02:17 AM   #3
kast1376
kast1376's Avatar
Quote:
Originally Posted by TRamsdell View Post
This is Stoopid. Sign the more holes with more power into a Mishri petition.
Fixed your typo.
kast1376 is offline   Reply With Quote
Old 05-19-2018, 04:12 AM   #4
08'MustangDude
That's what happens when you don't build them like you used to.
Those Hemi engines are NOT the same from the past. It's not
just the Hemi motors either.
Ford Escort 1.9 SOHC, Engine VIN Code J, 1986 thru 1996
Ford Escort 2.0 SOHC, Engine VIN Code P, 1997 thru 2005
Ford Focus 2.0 SOHC, Engine VIN Code P, 1997 thru 2005
Jeep Cherokee 3.7 SOHC, Engine VIN Code K, 2002 thru 2010
Jeep Liberty 3.7 SOHC, Engine VIN Code K, 2002 thru 2010 (mine was fine)
Jeep Cherokee 4.7 SOHC, Engine VIN Code J,N,P 2002 thru 2009
Dodge Dakota 3.7 SOHC, Engine VIN Code K, 2002 thru 2010
Dodge Durango 3.7 SOHC, Engine VIN Code K, 2002 thru 2010
Dodge Pick Up 5.7 Hemi, Engine VIN Code D, T, Z, 2003 thru 2009
Dodge Ram Van 5.7 Hemi, Engine VIN Code D, T, Z, 2003 thru 2009
Dodge Ram Wagon 5.7 Hemi, Engine VIN Code D, T, Z, 2003 thru 2009
Dodge Charger 5.7 Hemi, Engine VIN Code H, 2005 thru 2009
Dodge Magnum 5.7 Hemi, Engine VIN Code H, 2005 thru 2009
Dodge Charger SRT 6.1 Hemi, Engine VIN Code W, 2005 thru 2009
Dodge Magnum SRT 6.1 Hemi, Engine VIN Code W, 2005 thru 2009
Dodge Viper SRT 6.1 Hemi, Engine VIN Code W, 2005 thru 2009
They used powder metal technology (PM) valve seats with an approximate depth of
.286″ (7.264 MM). Inadequate heat transfer may have a part in these seats coming
out of the counter-bore; they expand thus the valve seat drops, which leads to contact
with the valve & pistons. When these seats shatter, many pieces result. Those pieces
end up in the cylinder, and most likely scores the walls and causes other damage; to
getting stuck in the head above the valve.
These engines run at a higher than normal combustion-chamber temperatures because of
an engineering flaw in the piston ring landings. EGR can't be adjusted enough to counter
that, and even if it could, would have a bigger impact on power and torque. To make matters
worse, the heads have smaller drain back holes in them so it's like a frying pan. This causes
oil to burn off faster causing sludge and build up that can lead to oil starvation.
One aftermarket PM valve seat manufacturer is now using different seat materials;
processes and designs that have resulted in improved seat insert retention in the cylinder head.
An additional tempering process was implemented, to eliminate the embrittleness commonly
found in PM seats. They also have additional seat depth and a reduced leading edge chamfer.
That provides an increased seat to cylinder head contact area for better heat transfer.
Chrysler doesn’t want to admit (neither does Ford) they even have this issue. You won't find any TSB’s
either, for those suspect engines from Chrysler or Ford.
This failure has happened as soon as 100 miles, to 156,000...
Valve springs are breaking too.
Chrysler's 318 was a work-horse, and they should have built on that. That thing
could go 300,000+ miles, but that's probably why all these companies drop their
immortal engines for ones that they know will fail. I know a guy who had two
318s in his house boat, and never had any problems with them.
08'MustangDude is offline   Reply With Quote
5.7L LS1 vs 5.7L Hemi & 6.0 LS2 vs 6.1L Hemi 1BAD3V Street/Strip 74 07-12-2007 11:59 PM
Petition to bring motorsports back to SPEED TV 95Stealth302 Other Professional Racing 15 05-21-2006 10:10 PM
2005 Mustang in Europe petition Capix Off Topic 17 06-06-2005 09:25 PM
Stop ashlee simpson petition. Off Topic 30 01-21-2005 04:17 PM
missouri front license plate petition needasnake Mid West 0 04-16-2004 02:19 PM
Featured Sponsors
