Impacts - Page 2 - MustangForums.com
Go Back  MustangForums.com > Other > Off Topic
Reload this Page >
Impacts
Impacts
Old 12-27-2018, 09:50 PM
imp
imp's Avatar
Originally Posted by TRamsdell View Post
no no no. In fact you can even get a manual impact that you smack with a hammer. Zero no load rpms. They wrork super nice for stubborn soft bolts in small engine cases.
No no no, what? You fail to understand my point about impact loads. Extremely high forces are reached by hammering, far higher than can be
reached by just "leaning into a wrench".
What I'm saying is this: If you lay an object on the table, the force is equal to the weight of the object. If you raise the object up a bit off the table and DROP it, the force which hits the table is a MINIMUM of twice the weight of the object. Many times more, if dropped from higher up. This is called "impact loading".
imp is offline
Old 12-27-2018, 10:01 PM
TrimDrip
TrimDrip's Avatar
so apparently the impact I posted has an auto feature. Which basically means it loosens at its 250 ft. lbs rating and tightens to 10 ft. lbs
I think I am going to do it, if i can justify spending that much on it. I could probably go by the pawn shop and get a dewalt for $100.
TrimDrip is offline
Old 12-27-2018, 10:46 PM
99GTvert
is my username.
99GTvert's Avatar
18v unit instead?????
99GTvert is online now
Old 12-28-2018, 04:56 AM
TRamsdell
IN JAIL!
TRamsdell's Avatar
you misunderstand. You can get way more power on a nut with a wrench esp. With a torque muliplier. An impact works by repeatedly hammering at the nut. Its not really the same concept as dropping a case of beer on your picnic table
TRamsdell is offline
Old 12-28-2018, 05:08 AM
TrimDrip
TrimDrip's Avatar
yeah, that is the only reason I haven't pulled the trigger. When Milwaukee started making tools, they had the 12 volt stuff, then they jumped it up to the 18 volts stuff. Now they are going back to the 12 volt stuff with a longer lasting battery for the 12 volt stuff.
The thing about the 18v impact 3/8" impact, is it is the size of the 1/2" impact. That almost makes me want to just go ahead and buy the 1/2" impact and just get a 3/8" electric ratchet.
decisions decisions
TrimDrip is offline
Old 12-28-2018, 05:18 AM
TrimDrip
TrimDrip's Avatar
Here is a video of the other one I am considering. It did take a Honda crank bolt out. That is a pretty big feat. If you are bored, look up on youtube how many breaker bar extensions people used to get a Honda crank bolt loose.
TrimDrip is offline
Old 12-28-2018, 04:44 PM
HRnB
Administrator
HRnB's Avatar
Just don't cheap out. I got one as a gift from Harbor Freight. Garbage. It's good for light work like fixing a bike, not lug nuts. I needed one mainly for the desert to swap out to sand tires on my side X side and truck. The cheap one is fine for the quads. I ended up buying a Makita. It's great.
HRnB is offline
Old 12-28-2018, 06:25 PM
TrimDrip
TrimDrip's Avatar
haha, 50 seconds in and i'm sold
TrimDrip is offline
Old 12-28-2018, 08:14 PM
99GTvert
is my username.
99GTvert's Avatar
Which cheapy harbor freight one you have?
Old 12-28-2018, 09:46 PM
imp
imp's Avatar
You just haven't studied Strength of Materials or Mechanics of Stresses.
imp is offline
Quick Reply: Impacts
Featured Sponsors
