First oil change at 20K miles.
#21
Yep; I guess I'm "old school"... I built or rebuilt an average of one engine a week for nearly ten years at a well respected British repair shop, and that's what worked for me, and what I told the customers to follow. Rarely ever had a single problem...except when I had to fix some of the boss'es builds that leaked.. Anyway, it can't hurt anything by changing oil more often, other than cost of oil & filter. I like the peace of mind I get, removing any and all potential contaminants, and believe me, there are some in the factory fill! The sooner that first oil comes out, the better I sleep. While those particles probably won't hurt anything, do you really want them imbedded in your bearings? Not in my engine; thanks.
Hey, whatever turns your crank.
Cheers.
#22
It's more about the add (additive) pack and viscosity improvers in the lubricant that effects the oil lifespan. Cheap, off the shelf dino oil cannot live past ~3000 miles before breakdown and viscosity degradation occurs. Most syn oils are good to *at least* 10k mile intervals. And recent technology oil filters typically filter down to <25 microns so taking the oil out to 20k miles w/o affecting vis or wearing out the additives is now common. FWIW, I did my first oil change at 500 miles using factory fill, again at 1500 with factory fill and yet AGAIN at 5k miles switching to synthetic at that time. A buddy of mine who ran his factory fill out to 10k miles spun a bearing with less than 20k miles on the car. So....
#23
The only way I would EVER follow the first 20,000 OLM interval on the new Mustang is......
Buying the car, and immediately dumping the factory fill and.....
Pouring in 8 quarts of Amsoil 0W-30
Gone are the days of "required" 3,000 mile oil changes. Even Ford's synthetic blend can achieve 10,000 miles with an 8 quart sump. 2 extra quarts makes a difference in an oil change interval. You have 2 more quarts of added anti-wear agents and cleaning detergents.
#24
Yea, I promise I have not reset the IOLM. It is clear that the first go around this is setup for 20K and then 10K afterward. Also, as I said, even ford's online maintenance schedule mentions nothing about having anything done at 10K miles. It's just strange, so what I am wondering is if they are using something different from the factory to make that 20K then going with the published recommended oil afterward.
#25
http://www.mustang50magazine.com/tec...te_oiling.html
http://www.mustang50magazine.com/tec.../photo_45.html
#27
I'm not advocating 3,000 mile oci's either but I think that might be pushing it on a blend like that in this engine
#28
My dads cobalt has the oil life %. The local Chevrolet dealership said it's based on the number of rotations of the motor. He said he recommends changing before it hits 50% left. Not sure why the oil life % last so long. It would be around 15k miles of normal driving before it reached low %.
#29
If the new 5.0 was a 6 quart sump, I would agree with you, and also would only suggest a maximum of 7,500 miles. The difference is, the new breed of 5.0 has an 8 quart sump. The 2 extra quarts make a difference in the amount of additives present in the sump to clean and protect an engine. This would easily make it capable of the extra 2,500 miles....although, I wouldn't suggest more with a few UOAs that says the oil in question could achieve it.
#30
Does Ford have some kind of special break in chemical with their oil with the 11's? I am on the fence also with changing my oil. Right now I have 750 miles on it. Thinking about changing the oil at 1500 miles with Mobil One then around 5000 miles changing it with Amsoil.
