Help! 2010 V6 - Transmission Fluid Change
2010 Mustang V6 - AUTOMATIC
As the subject states, I'm at about 50,000 miles, should I be looking at change my Transmission fluid anytime soon? I have many questions!
-Whats the process like?
-How often should I be doing it?
-Do I need to do a flush or just replace the fluid?
-Are there any filters that need to be changed?
-How much fluid will I need and what do you guys recommend Amsoil or Royal Purple?
I can answer most of your questions and I do not even work for AMSOIL.
If you want the complete benefit from AMSOIL or RP then you will need to flush. Drain and fill will not do it.
You posted in an AMSOIL sponsored thread... so they will tell you AMSOIL of course. Both are good.
For the other questions refer to your owners manual.
inyadreems
28
03-16-2009 08:39 PM
