No drag racing! Any other road race track addicts here..
RE: No drag racing! Any other road race track addicts here..
I do quite a bit at Hallett here in Oklahoma. I need another car to take out.. sold my last few that I have used. I have my Highspeed Touring License for their track and if I ever decide to keep a car for more than a year I'll eventually get into their comma point system.
Check out my car domain, I have some pics on it of the vert going around the track and plenty of videos on my youtube.
Hallett is a great track. I have only driven there once and it was in 2006 with NASA.
I had a brake line break on me going into "StopSign" during a race. The bad part was that I was going to make a late-brake pass on the inside when this happened. I swerved to the right and missed another car by 1 inch. Below is the link to the video.
http://www.tek-racing.net/bad-day.wmv
I haven't raced there since but am going back in June!!!
Man, Micheal - I had not seen that video of you before..!! That was close ! (was that Al you nearly clippeed?)
I am hoping to run with you guys at Hallet this June...if not for sure at Eagles Canyon in October....just depends on work schedule.
It was actually Daron driving Adam's car. Luckily everything worked out great as I don't think you could have fit a piece of paper b/w us.
If you can make Hallett that would be great. We will hopefully have a 35+ car field if all of the Colorado guys show up. That many cars on a 1.8 mile track should be awesome!!!
Glad to see I am not the only one!!
If you are not taking your car out on the road coarse, you will after you are done looking below:
http://www.bekkersracing.com/
Sebring
http://www.youtube.com/watch?v=Pk3rXv1UPw4
Moroso
http://www.youtube.com/watch?v=8Pw0rm-Gx4s
http://www.youtube.com/watch?v=tiT_sjRMcFk
http://www.youtube.com/watch?v=X_8AsEY0Rsk
http://www.youtube.com/watch?v=In8Yn3pggqU
http://www.youtube.com/watch?v=iSCKjRMrZtM
http://www.youtube.com/watch?v=pjjxzFnpfR0
Homestead
http://www.youtube.com/watch?v=Og0whRwqoc8
http://www.youtube.com/watch?v=SgPYJYah-UI
http://www.youtube.com/watch?v=aLWez1awq6A
http://www.youtube.com/watch?v=kPyiE51EZgI
http://www.youtube.com/watch?v=bFwFZ_Ed7V0
http://www.youtube.com/watch?v=09ernu18K2M
Road Atlanta
http://www.youtube.com/watch?v=XscKA...ersracing.com/
http://www.youtube.com/watch?v=XMktykU_pYY
Barber
http://www.youtube.com/watch?v=gaCFdwyS_rM
Roebling Road Savanah
http://nl.youtube.com/watch?v=EHp_AC9tDSY Part I
http://nl.youtube.com/watch?v=5uCn-dJT8VU Part II
Bay Bottom Crawl
http://www.youtube.com/watch?v=pqQS2KLLxkc
Pocono Raceway
http://www.youtube.com/watch?v=sB4whFh9eZ4
Daytona International Speedway:
http://www.youtube.com/watch?v=Kww5zB20aKY
VIR
http://www.youtube.com/watch?v=1ePEFYYpZMk Part I
http://www.youtube.com/watch?v=kb_2BYPR9FQ Part II
Sebring
Moroso
Homestead
Road Atlanta
Barber
Bay Bottom Crawl
Pocono Raceway
VIR
im getting into track racing now and it sucks!! so damn expensive haha but i do love it. I just need some help . .what would be a good first couple of mods to start off with to eliminate some body roll so its safe for me to run on slicks.?
The Mustangs, like most domestics, weren't designed with cornering in mind, that said, a good set of struts/springs will help you out. Unlike drag racing and street racing, the focus isn't power, it's handling and braking.
Struts
Springs
Brake Upgrade (Slotted or Big Brake)
Bigger Sway Bars
Panhard bar, 5-Link or IRS setup in the rear
High Performance Tires
Chassis Bracing
Like I said, your focus should be handling and control. Focus on that, once you get that going properly, get some BOOST UNDER THE BONNET!!!!
-Stig
Struts
Springs
Bigger Sway Bars
Chassis Bracing
-Stig
First off, is this your daily driver, street / track car, or dedicated track car? If you still drive your car on the street you don't want to go so crazy that it feels like crap on the road.
I would first get a good set of brakes. How much is your car going to weigh with you in it? 3500 lbs, 3300, 3100? The last thing you need to do when starting out is go spend the money to get 4 piston calipers and fancy slotted or drilled rotors.
FWIW, my car weighs 3150-3200 w/ me in it. I have stock Cobra dual-piston calipers w/ 12" factory Crown Vic. rotors and PFC01 pads. Unless your car is a pig this will be plenty to stop your car. It will also be very wise to put some sort of brake duct cooling on the car as well as stainless steel brake lines (from Maximum Motorsports) and a proportioning valve. Starting out you can leave your stock rear disc as is.
Suspension - Get a set of subframe connectors.
H&R sells great entry-level springs. I would go with either the "Race" or "Super Race" springs. The super race spring is going to be stiffer than the race. Again, are you going to still drive the car on the street?
A good set of shocks is a must. I prefer either Koni or Bilstein. The Koni's will be adjustable and the Bilsteins will not. I have run Bilsteins "race valve" shocks from MM for the last three years and they have done great. I plan on changing to Koni DA's for more adjustability.
With sway bars don't always think that bigger is better. It's not always bad for a car to roll a little so it will transfer weight to the outside tires. The different stock bars will give you a good amount of adjustability to start tuning your car. You can even try running w/o a rear bar on your car. I took my rear bar off over a year ago and loved it, haven't run one since. Also play with the tightness on your front end links.
The factory rear suspension on a Mustang sucks. There is so much bind with the 4-link it is crazy. Start with a set of lower control arms from Maximum Motorsports. You can run a panhard bar with a factory 4-link but you might not like the way it feels. The panhard bar creates more bind in the rear and could cause more snap oversteer. Later on down the line I would look into a panhard bar but not starting out.
Also, wheel spacers can be your best friend. Start with a set of 1/4" and 1/2" and try them front and rear and use them to tune accordingly.
Mustangs were not meant to turn corners but with a little work they get suprisingly good.
mungodrums
10-07-2015 04:01 AM
09-09-2015 10:30 AM
mungodrums
Suspension
09-07-2015 07:22 PM
