STS turbo = POS!!!!
RE: STS turbo = POS!!!!
ORIGINAL: FoxGT
Clearance on their setups is about as big of an issue as stock exhaust hitting on things. The turbo is usually mounted by the rear wheels, making it even harder for you to scrape the turbo on the ground.
ORIGINAL: 1QuickShortBus
Well not everyone lives in the desert, besides water is the least of the problems with that system. Complicated piping that is routed way too low, oiling and torque curve are much bigger issues to me.
Yes except for STS ran the piping under the rearend on S197s and under every crossmember the car has it deffinetly has clearance issues, other kits may not but the S197 kit does.
STS recommends the single turbo kit unless you have upgraded the engine. I have the STS twin turbo kit, and pretty much a lot of what was stated is untrue. I have never had issues with water, rocks, potholes or even speed bumps. We have driven through some pretty heavy downpours. I can safely do through all of those and have never rubbed any of the piping. Steep inclines or steep approaches to driveways can get a little hairy, but the same thing happens if your car is lowered.
As for spool up, we're spooled up by 3000 rpms. Last week, we dyno'ed the car again. On 12 lbs of boost we put down 547rwhp and 565 ft. lbs. We are in the process of changing a few things and are expecting to see 600 rwhp by the time we are done.
Just thought that I would post up some facts from someone that has the system.
When was the last time you drove through a flooded area? I never said anything about rain. I said if your whole tailpipe got submerged. & your full boost should be reached at the same if not close to a similar sized setup because of the smaller exhaust housing that has to be used & efficiency takes a hit because of that.
People get the STS remote mount system for the same reason people buy axle-back exhaust. THE WICKED SOUND!
true there are alot of other turbo systems that are 10x more effective (i.e. powerhouse) but damn, remotemounting your turbos under the car? you ever hear one of them drive by, orpullp to one at a light? you crap your pantst just sounds OH... SO! EVIL!
not tomention the sleeper potental, as theonly indication of the turbo is the intake tube coming from under the car... but then just tell the guy thats the best place to get your air from
i dunno guy my buddy has a ws6 with the sts kit on he just ran 11.50's with a horrible slipping clutch on radials he made around 600rwhp with his kit at 12psi i guarentee once the clutch is swapped on some slicks hell get 10's no problem theyre not that bad they work
ORIGINAL: Grabbn 07
ORIGINAL: Sap
I mean, we get what, 4, maybe 5 rainy days in CA and its definately not enough to flood or get up to where a turbo would be.
not a fan of remote turbos but if you have to pass smog like use CA guys, this might be a good way to hide them from the smog tech. there is a guy on turbomustangs who was building is own remote turbo kit on his 05 or 06gt and he cut off the back of the stock muffer and used it to hide the twin turbos so from behind it looked stock.
ORIGINAL: FoxGT
"With so long of intake and exhaust tubes, doesn't it take a while for the boost to build up?
No, our intake tubing volume is about the same as most conventional turbo setups that are running a front mounted intercooler, and less than many of them that run large intercoolers. We aren't talking about a small compressor filling up a large air tank, we are talking about a huge compressor filling up a very small volume which only takes a fraction of a second. Our systems compress the intake tubing in about .05 seconds. So much for turbo lag..."
ORIGINAL: BadSTSpony
Ummm... never. I don't make it a habit to drive through flooded areas. Not even in my POS daily beater. If I were to submerge the turbo, I'd have water almost half way up my doors.
It takes the exhaust gas longer to get there & from the piping the gasses have cooled & got more dense in a rear mount setup. The whole intake part has a very very small role in lag time. The most time consuming part comes from the time it takes the cylinder to get high exhaust gas volume to the exhaust & spin it.
Looks like they're just good with words, but I guess that's what it takes to sell a product.
