PURGE PROBLEM
i have a nitrous soleniod that only has in and out ports on it. now i know that nx brand has a port underneath. so that is self explanatory, but with mine its a edelbrock solenoid, i dont know how to make it purge, any help is appreciated
RE: PURGE PROBLEM
if its not a purge soleniod that u cant use it as a purge because n e other solenoid has constantly running nos threw it the hole time but a purge solenoid blocks the nitrouse until u press a swicth then it will open up
RE: PURGE PROBLEM
Its a nitrous soelnoid, i was wanting to know if it was possible to still be able to plug a purge solenoid up to it even though it only has a in and out port and not the extra 3rd one.
RE: PURGE PROBLEM
PM the NOS/MAN, I'm fairly sure he can answer your questions if you can only understand his answers! hahahaha
RE: PURGE PROBLEM
You can use the solinoid you have, just T into it like this. Purge solinoids are just small nitrous solinoids.
The line on the left with the blue fitting is the main line from the bottle, it goes into the T fitting, then you will need a short peice of line to go from the other side of the T to your n2o solinoid. Run another line from the outlet side of the purge solinoid to where ever you want the purge to come out. [IMG]local://upfiles/7038/9E5E0B92384B427EB3DE69570A65CB42.jpg[/IMG] [IMG]local://upfiles/7038/A177142037014BF2A6AC6D432599E56B.jpg[/IMG] |
