SuperCharger Help!!
SuperCharger Help!!
I have a 92 Mustang and a Vortech A-trim setup, T-rex fuel pump,fmu,ignition w/boost retard,30lbs injectors, the problem is the sc bearing is shot and i dont know what to do?? I need the car to run, how much is it to rebuild a sc?? What would I have to do to get it running?? What would I have to take out, and put in?? Thanks for any help
RE: SuperCharger Help!!
All you will have to take off is the head unit and send it to Vortech. I dont know the exact cost but I hear the rebuild is fairly inexpensive. If you take off the head unit there is really no way to make it run unless you go back to the stock injectors and pump or you will be running to rich to be safe.
you should be fine with the 30s think about it how dose it idle is it real rich?you could also drop the fuel press. some if need be.the fmu will not work with out the supercharger making boost.so that is no big deal.I ran the wifes around with 42# injectors and the belt off and it ran just fine the Ford EEC is a good system and it will help out alot.
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
