Can I install the Vortech?
RE: Can I install the Vortech?
Tapping isn't hard. Just drill the hole the right size, then use the right size tap, lube it up with some grease to catch the extra shavings and basically screw it into the hole. Kinda straight forward. I was nervous the first time I ever had to use a tap (and die), but after a day in class it was quite easy. If you want you should purchase a peice of junk oil pan from a junk yard and just practice on that. After 2 or 3 holes you'll be confident enough to do it in your sleep. From what I've heard, it's a lot easier to tap oil pans if you remove them, although I haven't spent much time under the engine to see if that is true.
Here's a tutorial from the site you probably ordered half your parts from:
http://www.superchargersonline.com/content.asp?ID=30
And here's a link to the install manual:
http://www.vortechsuperchargers.com/...FH4FL218im.pdf
Yeah, that is what I was planning on doing.Maybe not buy an oil pan to practice on, but an equivilant thickness piece of metal to put holes in. Either way, good idea and I definately plan on doing just that. I'm still looking for a MAF, injectors and a fuel pump, though. If anyone can point me in the right direction to get a good deal, let me know And thanks to all for the help on this one.
LOL, that's an option, but one problem: I can't weld I haven't a clue how to use those things. I suppose I could take it to someone and have them do it. Couldn't be that hard I guess Thanks for the idea, I might just do that.
I bought everything he said up top, plus the coil bracket. The total came out to a bit over $700. The 97 GT's are appearantly a little cheaper to set these things up. After I got all that, I bought a boost and fuel pressure gauge for$88 shpped.The used head unit cost me $500. That puts me around $1300 right now and I am still missing those other three, but that's all I need. I'd like to keep it at $1500 if I can, but I might not be able to. That's why I'm asking around to see if anyone knows of any deals.
ORIGINAL: banned
you can go to any muffler shop / etc and have them weld it for you - they shouldnt charge more than 20 bucks - and it would be well worth it imo
ORIGINAL: Willem_Black
