N20 for 96 cobra, zex? NX? NOS
yea 150 would be alot. I say start with a 75 shot and work up to 125 reading the plugs and adjusting timing. 150 can be done but it takes a much better tuner and is pretty hard on rods (pistons will be fine as long as its tuned right).
I would go with a Zex kit, and a Steeda Timing Adjuster for your Cobra. So you can retard your timing. Experiment with 75 first on your Cobra, then increase. My buddys 98 Cobra has run many of bottles @ a 150 shot in his Cobra with not a problem. Zex is by far the easiest install. Zex will also be introducing some new products, intake plates, I forget off hand what intakes the will work with, and also direct port nitrous. The new products are designed to work with current Zex Nitrous units.
11-10-2015 11:39 AM
Dan04COBRA
09-30-2015 11:46 AM
