new to the turbo scene!!!!! HELP MMMMEEEEE!!!!
so anyways , has anyone ever heard a song that has inspired them to build a car around it? anyone? no? ok well i have, judas priest need i say more? anyways i want to know every thing i need to about turbos, yes i tried the turbo sticky but it was kinda like "huh?" for me so could someonetell in lamens terms what it all means, anyway could someone give me the lowdown on what i would need to build a twin-turbo, inter-cooled, 1200-1400 hp race car?, i can handle the build and cost, basically what i need is for someone to pic a pair of turbos that could handle this and a GREAT intercooler, i was planning on use a water/methanol injector system(yes ok i swear up and down about them), of course i would use a billet rotating assembly, gonna use what is basically and 825cid aluminum boss 429, 5.25in stroke and 5in bore, crazy huh..... anyways this should be enough for the cubes, just find the turboes and explaine the princaples please!!!!!!!!!
RE: new to the turbo scene!!!!! HELP MMMMEEEEE!!!!
Is pump gas a requirement? And is this going to be a street car that is driven often? I've never seen someone use that big of an engine for a daily driver, but I do know a couple people with around 1200hp in their daily driver cars, but on race fuel, not pump. at 25-30psi. These are stroked 302 & stroked 351w engines though.
In any case, you need to figure out what size engine you plan on running for sure, then the max rpm you're going to run. Then I could look at some maps for you, but you're probably better off talking to a turbo manufacturer like garrett.
These may give you a better idea of a starting point.
http://www.hotrod.com/techarticles/e...gas/index.html
http://www.hotrod.com/projectbuild/h...ild/index.html
hey what's wrong with "turbo lover" anyways no this is not a pump gas car race only, like torco m-118 fuel, so no no going on the street
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
