supercharger advise needed
ok i just picked up a vortech v1 s-trim...has 8 rib pulley set-up..was told its a 10 pound pulley..i need to get new injectors and mass air set-up...my current setup is in my sig..my question is what injectors and mass airset-up do i upgrade to...i wontbe running an fmu because i will be having a custom tune done...i want to make at least 450 to the wheel if not more...i will be installing a mr freeze meth injection kit also. thanks
ok cool..i was told to get 60lb injectors not 42's but ill get 42's then and a 90mm lightning maf....what else and im going to need besides injectors and 90mm mass air....im getting a 70mmm throttle body, and for the price of a 255lph pump i can get a new vortech t-rex pump kit....will i need fuel rails also? i was looking into getting them
just so you know that pulley doesn't mean you'll get 10psi, it will depend on your crank to supercharger pulley ratio & how much lb/min the impeller will move at that speed, so don't try going out & flooring it first chance you get, roll into it so you don't kill it.
