v6 exhaust Q
v6 exhaust Q
i have a 99 v6 and the magnaflow cat back. it sounds great at Wide Open Throttle but under 2k rpms it is quite. what do you think about taking off my catback and running from headers --> cats --> turn down tips before the crossover in the y pipe?
RE: v6 exhaust Q
You need to get rid of the stock mid pipe. A correctly dumped system on a Mustang should throw the exhaust out just before the rear axle. Id say keep your catback and run an O/R midpipe if its allowed in your area. If not then try a High Flow midpipe.
RE: v6 exhaust Q
i have a v6, so if i ran an o/r mid pipe id need a new cat back or highly modify (no offroad y pipes out there). plus i want to remain catted b/c i hate the uncatted smell and i want to be legal if i travel
i could get a muff shop to fabricate from right before the Y of the ypipe with turn down tips there (no muffs that way) OR i could get a muff shop to put in 15" of straight 2.5" piping to go where my 14" long muffs are now?
it would be cheaper to turn down tips before the y, but it would look better to straight pipe the muffs IMO. what do you think?
RE: v6 exhaust Q
ORIGINAL: AtlanticBlue99
RE: v6 exhaust Q
yea, i dont want to spend a ton of money and i am probably going to just keep it the way it is and maybe later ill straight pipe the muffs. the more i think about it, it isnt worth the money to get another catalytic converter (high flow or not) or mid pipe if i am going to need some fabrication anyway. i can get my friend to weld in some 2.5" aluminized steel where my muffs are now, but i cant justify spending the $ for just a better sound...
and i was throwing out the easy option first- delete cat back and turn down tips after the cats so it is legal but louder.
but then i got to thinking, keep my cat back and delete muffs. it will cost me the price of the piping (30" of aluminized steel- roughly 30 bucks) and i keep my rear exit which i like appearance-wise more than turned down halfway under the car.
RE: v6 exhaust Q
Dont rush any decisions though. Ive found that out the hard way with previouse vehicles []. Put some good thought into it and youll find somthing that youll be happy with. Good luck with everything, sorry I didnt help out a whole lot .
RE: v6 exhaust Q
like i told you on another site its gonna sound like poop. no mufflers on a V6 dont mix to well. no matter how much money you spend youll never get a v6 to sound aggresvive like an V8. its gonna sound like a chain saw. think long and hard before you make your decision. good luck.
