Question about Vortech Pulley size and boost. Is anyone
running a 3.125 pulley with a front mount intercooler. I have 10 lbs boost now, and would like to keep 10-12 lbs even after the FMIC is that the correct pulley... It is a 6 rib system, should I be slip free, going from stock to 3.125 thanks Brian
im confused. You said you have a 3.125" pulley making 10 psi correct? Are you saying that is without the intercooler? And now you want to know if you will still make 10-12 lbs of boost once you install a FMIC? and what do you mean from stock to 3.125? What size is your stock pulley?
I'm having trouble understanding your question.
If this helps, I have a FMIC makin 7.76 (max) lbs of boost w/ a 3.6" Pulley
a 3.33" pulley w/ FMIC made ~ 9 lbs of boost
so that would mean 3.125 should net you about 10 lbs like you want. I wouldn't expect more then that though. Unless u add a power pipe (if you dont have one)
My fault, yeah I have a stock 3.60 pulley, making 10 lbs. Non IC
I do have an anderson Power Pipe, but I just purchased a 32x12x3 FMIC.. A vortech Mini Race Bypass.. With these mods I made 360, I want to drop to a 3,250 or 3,125 pulley. up my timing and my fuel, and keep the boost around 10-11.. Do you think I can add 30 HP with doing these mods.. Thanks... is the cam worth it.. are your internals Forged? Thanks again Brian
its not that the intercooler is restrictive, its that its extra space that has to be pressurized, a LOT of extra space. think about how much added tubing and IC space you have compared to the stock discharge pipe. it takes more effort to pressurize a larger area.
Yes. I made 377 rwhp and 370 rwtq with 3.60 pulley (10lb peak) and it was non-intercooled. I plan on getting back to the dyno next week sometime for new numbers. I just wanted to go through everything again one more time before i commit to it. I also added cats to the car because of moving to VA for emissions and inspection so I am curious to see how they affect it too.
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
11-09-2016 11:44 AM
NorthAmericanTuning
03-18-2016 11:21 AM
Soldier GT
08-12-2015 03:46 PM
mustangsrforever!!!
08-06-2015 12:04 PM
