re: Air Tube to Catalytic Converters
I have a 1994 5.0 and am in need of the air tube that connects from the valve to the Catalytics. I will be installing the 4 catalytic converters as required with a 1994 and believe that the air tube branches out in a "Y" to connect with 2 of the 4 converters. The mechanic installing the Cats told me that I will need to find the connecting air tube. Does anyone have a way for me to identify this part with the proper name, so that I may be able to find a used or new tube that will work?
Thanks,
vincesf
Thanks,
vincesf
Exactly what you called it. AIR tube from the catalytic converter to the check valve. Being that you are in Cali the auto parts stores should know what you are talking about. Less common in cars with federal emissions of that year. It should be listed in their Emission system catalogs or check our ROCK auto . c o m under the emissions category (Air Injection Pipe) for your car. It's listed there for $25-40
