Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
does anyone know tbe difference between 94-95 longtube headers and 87-93 headers
Old 10-24-2013, 04:11 PM
ironwonder1
ironwonder1's Avatar
Default does anyone know tbe difference between 94-95 longtube headers and 87-93 headers
Ok I have a 91 hatch and 94-95 long tube headers but before I put them on has anyone done this before? I've had tons of mustangs but I've never tryed put sn stuff on a fox will they work?
ironwonder1 is offline
Old 10-24-2013, 04:35 PM
dawson1112
dawson1112's Avatar
I think the difference is that the 94-95 long tubes are spread a little further apart than the fox body. You may have to use an O/R h or x pipe for the 94-95. I used a set of fox body long tubes on my 94 and had some clearance issues at the t5 trans where the clutch fork is. I had to flatten one of the primaries to clear the trans. My headers that I used came with an h pipe designed for the foxbody and I had to cut the cross pipe and put a sleeve in to make it wider. There has to be a difference because when you order long tubes the ones for 94-95 say they only fit those years and visa versa for the fox headers.
dawson1112 is offline
Old 10-24-2013, 05:00 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
one of the biggest differences is that the 94-95 headers have the egr provision where foxes dont
rmodel65 is offline
Old 10-24-2013, 05:06 PM
dawson1112
dawson1112's Avatar
Yea the ones I bought were for a fox body but I made them work on my 94, of course the fitment issue may have been the fact that they were cheap obx header. I don't have much experience with the big market headers like mac or bbk
Old 10-24-2013, 05:51 PM
ironwonder1
Thanks! I guess I will try it worst thing they won't fit I'm just worried about my steering
Old 10-24-2013, 06:05 PM
dawson1112
dawson1112's Avatar
Just about all long tubes cause interference with the steering shaft. Not all but most its usually only just rubbing a little, most pple are able to ding the primary and get away with it some pple have been known to shim the engine up using washers. I had to ding my primary where it contacted the steering. the correct fix is to get an after market steering shaft with out a rag joint in it. I think the company is called flaming river that most use
Old 10-24-2013, 07:48 PM
ironwonder1
OK I'll look it up my car is just a shell so I'm buying piece by piece
Old 10-24-2013, 11:43 PM
84CopperGT
84CopperGT's Avatar
Maximum Motorsports also makes a steering shaft without the rag joint
84CopperGT is offline
Roxon68
03-17-2016 08:13 PM
Shadow7874
09-24-2015 09:06 PM
trashxtrash
09-20-2015 10:49 PM
BrantleyS550
09-14-2015 04:18 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: does anyone know tbe difference between 94-95 longtube headers and 87-93 headers
