Exhaust install
Just ordered a new magnaflow catback. Should I have it professionally installed or can I do it myself. Should it be welded or can I use the clamps it comes with? Thanks for any advice!!!
RE: Exhaust install
you'll just have to cut the old one off. the new one will bolt right on in it's place. shouldn't be that hard for you.
RE: Exhaust install
ORIGINAL: chuckv6 Just ordered a new magnaflow catback. Should I have it professionally installed or can I do it myself. Should it be welded or can I use the clamps it comes with? Thanks for any advice!!! |
RE: Exhaust install
Thanks for the advice! Last month everyone was talking big about Magnaflow, now all I hear is that it's really quiet. Anyone have an opinion?
RE: Exhaust install
Nanaki, what do you really have?
RE: Exhaust install
i have loudmouth 2s. magnaflows are quiet at idle and cruising around. not much louder than stock. they come alive when you get on the gas hard.
RE: Exhaust install
yeah definitely do it yourself. just know that the pipe that goes over the rear end can be a pain. and do not tighten everything down until everything is in place. if you bend your pipes with the clamps and then have to re-do it, youll be in a whole new world of frustration.
RE: Exhaust install
Nanaki, I meant what what year do you have and mods. Anyway, thanks for the advice!!!
RE: Exhaust install
04 GT 5 speed. 3.73s, LM2 catback, magnaflow catted X, vortech v2 sq, 42lbs injectors, inline fuel pump, AFM powerpipe, steeda tri-ax, subframes, kumho 275s
RE: Exhaust install
Man...how the hell did you afford that vortech?
