rear sway bar just installed
#22
RE: rear sway bar just installed
Hey Sevalley... I hope I am wrong here but I think you have installed your rear sway bar "backwards".
The little tag I see on your 2nd picture should say"left" on it, and the bends in the bar are supposed to give you additional clearance for the frame supportss that your bar is laying against in the 1st picture. The sway bar actually goes above the frame support rods.
I managed to get mine in without taking one of the tires off, but if it were 1 inch longer I would have to take off a tire to get it in place.
#23
I agree with Rrruss ... How do I know? Because I installed mine backwards too! Not until I was parked next to a GT at a car show did I notice that my sway bar was hanging way lower than his ... I flipped it around that night .... looks much better now ....
#24
Received my rear sway bar from Diversified. I only ordered the rear but in the box there's 2 bars . i think they gave me extra front. i only pay $80 plus 7 for shipping. Good deal and I will install it this weekend. First got to Home Depot to buy the nuts and bolts. Thank you.
Do you have the picture of your rear sway bar? I want to make that I installed it correctly.
#25
ORIGINAL: dmhines
Cool ... just got my front and rear GT bars today. I found another post listing the exact size bolts required so I am going to go the $10 Ace Hardware route for the nuts and bolts.
Four (4) - 8 x 16 bolts, nuts and washers for the lower shock mount ends
Two (2) - 12 x 65 threaded end bolts, nuts and washers for the links
Just installed my rear sway bar, I prefer 8 X 25 bolts because it is easier on the back. It took me 45 minutes and lots of patience in tightening the back. By the how do I know that did not installed it back wards.
#26
ORIGINAL: mustangpogi
ORIGINAL: dmhines
#27
Checke the back of my car and I can't even see the sway, So I must installed it right. Thanks
ORIGINAL: dmhines
If it is installed backwards ... you will be able to see the bar when standing behind the car ... and the sticker that says L for left ... will be on the right.
ORIGINAL: dmhines
#28
saleen take off GT front sway bar.... 30 bucks
http://www.saleen.com/SC101_Services...9-1303-C11739*
#29
Re-installed the sway bar correctly this weekend. This time, I had to remove one of the back tires to get the bar to fit into place, and it went over the vert support beams, not under it like I had. Taking the tire off also made it a million times easier to turn the bolts. I have not noticed any difference in performance from when the bar was installed upside down (lol), but I had a rattling noise which I thought were my blown shocks, which has since dissapeared, so my shocks arent blown, and instead of spending 500 bucks on new shocks, I just bought a new magnaflow dual exhaust system which I plan on installing next weekend.
#30
I have a2006 Ford GT rear sway bar for(.Give me 100US).Send me a PM.I am in Toroto area of Ontario canada.You pay shipping.Also a front sway bar.Both are new take offs.I bought the S3 Roush suspension.
