LCA fittament issues?
#21
RE: LCA fittament issues?
ORIGINAL: retfr8flyr
All the LCA’s will add road noise over the stock arms but I haven’t experienced anything exceptional from the CHE arms. I have the same ones you are looking at.
Earl
Earl
https://mustangforums.com/m_2009123/tm.htm
Richard
#23
I have BMR street lowers and BMR adjustable upper. I also have BMR lower brackets. Noise is not an issue at all but vibration is an issue if you are not expecting it. I wonder if a lot of you are feeling the vibration transfered from the poly bushings and calling it "noise". I gained .2 sec in my 60ft. times with my set-up. I would have been happy with .2 through the traps but .2 at 60ft is awsome. I went from mid 8.7's to low 8.5's with just the suspension change (this is in the 1/8th).
