Adjustable LCA's coming loose?
RE: Adjustable LCA's coming loose?
You mean the rear sway bar? I have a rattle in the rear the front is just fine.
The rear bumper cover shakes a little due to the cheap plastic push pins that hold it in place. I think i'll try replacing them with some aluminum bolts from the hardware store, but I don't see that plastic making the metallic noise i'm hearing.
ORIGINAL: 06GT4RAD
Moostang also check the front sway bar end links. Sometimes they do not get tight enough after resinstalling the new springs.
Richard
Richard
The rear rattle mystery has been solved and the answer is .................................................. ....................................
The LCA jam nut came loose!!!!!!!!!! I didn't see it the first time, damn that little nut can make a lot of racket!
09-01-2015 08:16 PM
