Advantage of staggered tires?
Old 10-23-2006, 04:33 PM
Blacksmoke
The Paranoid One
Blacksmoke's Avatar
Default Advantage of staggered tires?
Are there any advantages to staggered tires??
Blacksmoke is offline
Old 10-23-2006, 07:58 PM
scramblr
scramblr's Avatar
Default RE: Advantage of staggered tires?
Looks cool... [8D]
scramblr is offline
Old 10-24-2006, 10:25 PM
moosestang
moosestang's Avatar
Maybe if your going in a straight line.
moosestang is offline
Old 10-24-2006, 11:19 PM
CrazyAl
CrazyAl's Avatar
#1 Looks is probably the most obvious factor
#2 Optimization of traction/weight for going straight:
Wider tires in the back give you better traction at launch. But you don't need wider tires up front. Wider tires in the front is just excess weight, and too wide of a tire up front causes clearance problems. So, the solution is narrower tires in the front than the rear. Look at any serious drag race car and that's what you'll see. Skinny tires in the front and fat ones in the back.
...that brings us back to #1 becasue a lot people want to emulate the race / musclecar /hot-rod look by having large tires in the back and narrower ones in the front.
The obvious downside is that staggering makes rotating tires much more difficult. If your tires have directional tread then you can't rotate them at all unless you have them de-mounted and re-mounted again.
CrazyAl is offline
Old 10-25-2006, 01:20 AM
scramblr
scramblr's Avatar
ORIGINAL: moosestang
Um, Yeah [sm=exactly.gif] ...It's a Mustang and it's suppoed to be at the drags... [sm=burnout.gif]
scramblr is offline
jwog666
12-27-2021 08:09 PM
CS2007
06-25-2019 09:45 PM
KingRando
10-02-2015 08:06 AM
marc954
09-29-2015 11:18 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
Quick Reply: Advantage of staggered tires?
