ATTN suspension guys
I recently installed a set of steeda ultralite springs to lower my car 1" i also removed the front swaybar and now at like 5 to 10 mph my car clunks what could this be?...And today i am ordering a set of lakewood lower adj are they giving anyone problems?
RE: ATTN suspension guys
Where is your clunk coming from? There are a lot of possibilities. To name a few:
1) There could be something loose (not properly re-installed) in the front or the rear as a result of your spring swap. Make extra sure that all the bolts are torqued properly.
2) Some of these cars have a known "clunk" issue from the front end (even bone stock). There are many, many threads about this. Look around and you will be able to read all about this.
3) If you lowered the car but didn't fix your alignment then that could be a cause. Lowering without correcting the pinion angle in the rear is a known source of clunking.
musnicki
09-23-2015 07:11 AM
09-01-2015 08:16 PM
