Tires for a road course...
I'm going to Pocono Raceway next month and running on the Time Trials on the East Course. My only question is about tires, I know some guys say you'll be ok with stock tires and I probably will, since it's just time trials and I don't intend on pushing my car to its limits. I have a set of M/T ET Streets at home and I'm wondering if those tires are good on a road course or are they only recommended for a drag strip? I have driven with them in the street and it feels better taking turns, probably because they're wider than my stock tires.
RE: Tires for a road course...
NNNNNOOOOOO!!!!!!!!
DO NOT drive on drag slicks at a road course lol.
Honestly, this will obviously be your first time on a road course. Stock tires will be better for you for now until you learn how to drive. Any sort of r-compund tire willgive you a false sense of security and will mask verybad habits. Theycan getyouhurt.
What you do need to focus on is yourbrakes. Especially in the beginning you will use them too much - and that is normal. I would reccomend getting a set of Hawk hp+ or EBC yellowstuff pads and a pair of takeoff rotors. Throw in some braided lines and Motul RBF600 and you will be fine. Some people might reccomend better pads. In my case i use Hawk blue's, but they grab so hard the ABS gets a little tricky so you have to know the car. The Hawk hp+ will get mushy after some hard laps, mostly because as I said you will be on them toomuch.
Also - CHECK YOUR OIL. The 4.6's like to spin bearings when they are as little as a half quart low. With a stock oil pan and no accumulator - every drop counts.
Get some gloves - mechanix wear - whatever. Your palms will be sweatty lol.
Other than that - good luck, have fun, and be prepared to go broke LOL
I knew it was a newb question, but I had to ask it anyways!
I'm already planning on doing the brakes, fluidand SS lines before I go to the track. I wont be too bad though, it's only two practice laps and three times laps on a small track, I know I'll probably be hooked though, so that could be trouble!
ORIGINAL: RodeoFlyer
NNNNNOOOOOO!!!!!!!!
NNNNNOOOOOO!!!!!!!!
Good info
Also if you have the chance to have an instructer to ride with, jump on it!
Thanks guys, I really appreciate it. I'm going for the class that day so I can get my license, so maybe one of the instructors will go on a lap with me and give me some pointers.
I used Carbotech pads at the track...worked great.
Also, go with a full tank of gas...once your gas gets down to 1/4, hard cornering will produce an "almost out of gas" signal. Depending on the # and length of hard corners, the out of gas signal may not go away until you sit still for a while. This freaked me out and made me worry that the engine was going to erroneously cut off because the car couldn't see any gas in the tank. I missed a 30 minute session to go fill up and come back to the track.
ORIGINAL: dkano
ORIGINAL: Derf00
BFG KD are good. Great for dry, I wouldn't recommend them for any type of wet condition though.
Kevin
