GT Rear Sway Bar
So, i just ordered my GT rear sway bar off of New Take-Off parts online and was wondering if it came with everything i will need to install it (i plan on doing it myself). Do i need to order bolts or anything from Ford? Thanks
RE: GT Rear Sway Bar
w708737-s439 bolt quantity 4
w520213-s440 nut quantity 4 w711368-s439 boltquantity 4 w520214-s440 nut quantity 2 fordparts.com has these parts....you must order them in these exact quantities. For one of them you will need only 2 rather than 4 but they come in bags of 4. |
awesome, thanks!
ORIGINAL: nonstopred w708737-s439 bolt quantity 4 w520213-s440 nut quantity 4 w711368-s439 boltquantity 4 w520214-s440 nut quantity 2 fordparts.com has these parts....you must order them in these exact quantities. For one of them you will need only 2 rather than 4 but they come in bags of 4. |
ORIGINAL: 4Rowdy ORIGINAL: nonstopred w708737-s439 bolt quantity 4 w520213-s440 nut quantity 4 w711368-s439 boltquantity 4 w520214-s440 nut quantity 2 fordparts.com has these parts....you must order them in these exact quantities. For one of them you will need only 2 rather than 4 but they come in bags of 4. |
I just installed both front and rear sway bars today and it took a total of about 2hrs. from start to finish. I would definetly get the Ford clip bolts for the rear shock mount points, it made it a much easier install. Plus if you don't have one I would recommend getting a 15mm deep socket. It makes it much easier to tighten the nuts.
do the swaybars make a really noticeable difference? i'm curious[8D]
oh yea
