All BMR suspension?
All BMR suspension?
Im thinking of doing all BMR suspension. What do you guys think of this piece and the price? http://www.ninosport.com/BMR-Tubular...;category=6471 I will be getting a hurst short throw shifter also.
RE: All BMR suspension?
Seems like a decent enough piece, however, I would say there is a lot more you could do for the suspension first. Remember, the point of the K Member is to stiffen the body - which is stiff enough to begin with.
I'd look into springs, dampers, strut mounts, control arms, and a panhard rod/brace before worrying about chassis stiffening.
The Mustang's weak point includes wheel control, so address that first.
But when the time comes, and you have 900rwhp, this seems like a great piece! Though, as with all chassis bracing, tis' usually a good idea to have it welded in.
Griggs has a nice write-up on why they decided that the stock K-member wasn't good enough for their suspension system.
http://www.griggsracing.com/article_...articles_id=23
it is a good piece. it is stronger and stiffer. plus the motor mounts are definitely better. but..
like other have said there are many more things I would do first... like the whole rear suspension first. once you are done that then I might think about the k-member. also I would do the a-arms at the same time. look at the suspension packs on the Lethal performance site.
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
Matt's 95 Stang
10-05-2015 07:16 AM
