Current suspension plan . . . is it a good one?
Hey guys,
Thanks toRodeoflyer, F1Fanand many others I have been trying to research and plan out my suspension set up. Here is what parts I plan to go with: Prothane bullitt motor mounts $ 129 CHE 4 point K member brace with torque limiters with rod ends $ 171 CHE Severe Duty double adjustable panhard bar poly/rod mix $150 CHE Panhard brace $89 CHE Severe Duty double adjustable LCA poly/rod mix $220 Steeda Adjustable Competition UCA $280 Steeda Competition linear springs $330 Tokico D-specs $507 Steeda Heavy Duty Upper strut mounts $270 How's it look? Anything I am missing? Overkill at all for a DD that will see a 2-3 road course events a year? Do I really need the MM caster/camber plates or the Steeda Competition spring seats? Even with the Competition springs the front will only drop 1" and the rear 1.25". How much will the camber be off that I need so much adjustability (not to mention, they are $335). Thanks guys UrS4 |
RE: Current suspension plan . . . is it a good one?
All will be very helpfull.....the only thing I would do is rather than camber bolts buy some adjustable upper plates, will make all the difference in the world and you have it apart anyways ....
You will surely notice a big improvement in handeling but you will also notice a huge difference in noise transfer with the poly bushings....for me it was well worth it though !! |
If your on a budget I would cut out some of the other things before the camber plates...
Money spent on the G-trac brace would be better allocated to HD strut mounts (adjustable camber plates).
Maximum Motorsports c/c plates would be nice
If your going with a poly third link the differential bushing wont live long. It's a BITCH to replace. Either take the hit now and replace it with a Steeda spherical or use a rod end on the third link. You wont hear the Steeda bushing on the diff too much. |
ORIGINAL: RodeoFlyer Maximum Motorsports c/c plates would be nice If your going with a poly third link the differential bushing wont live long. It's a BITCH to replace. Either take the hit now and replace it with a Steeda spherical or use a rod end on the third link. You wont hear the Steeda bushing on the diff too much. |
you have multiple options. There are some with a rod end at the body side, or a rod end at both sides for adjustability while attached. The bushing in the diff will have to take more of a load when you reduce compliance, as with a poly bushing on the third link.
The Steeda competition link/mount is the best current choice. |
Okay RodeoFlyer,
I have made some changes to my list and asked a question. The stuff in my list is on the spendy side compared to similar products so do you think I am going overboard with all the HD mounts, caster/camber stuff for a DD that will see a few road course events per year? |
Slippery slope.
If you wanna run a couple track days a year, show up and run without f'ing with your setup other than a couple clicks on the shocks - camber bolts will be just fine HOWEVER If your replacing the strut mounts anyhow, as long as you have the front end apart, c/c plates would be a worthy investment, leaving you the option of adjustment down the road. If you decide you want them later, you will be paying for the labor twice. |
Okay RodeoFlyer,
How about the following amendments to my list. Ditch the CHE double adj LCA for BMR fixed length poly/rod mix LCA as having everything being adjustable means to me a lot of ways I can screw it or shop can screw it up trying to align everthing. |
