SWAY BAR DELTE SAFE FIR THE STREET ?
#21
RE: SWAY BAR DELTE SAFE FIR THE STREET ?
ORIGINAL: D_Gusler
No front sway bar here either. Just unbolted it and removed it. No delete kit.
#22
ORIGINAL: jwgroovin
I'm curious, do you haul *** around curves at all? On earlier Mustang platforms a swaybar delete was the kiss of death on the street if you tried to have fun on the curves. I'm tempted to get the BMR kit (and other front end weight saving components) but can't quite convince myself to make the car show/track only. While not my daily driver, every once in a while I still like to get on it.
John
ORIGINAL: nineinchnail1024
I've had the swaybar delete for months and can't feel the difference from when I did have a swaybar. (Unless I'm at the dragstrip!)
John
The point here is that whether there's a front sta-bar or not doesn't make a whole lot of difference when the driving is within any reasonable level of intensity. There isn't enough lateral load transfer happening or enough going on in the way of slip angles for most people to even notice.
Pressed for my own definition of "hauling *** around curves", for reasonably smooth pavement I might put it at 80% or so of the lateral g's published in the monthly magazines. Definitely hustling, but with at least a 10% margin on the absolute grip-limited speed. IOW, slightly north of 0.7 lateral g for most any cornering-oriented tire/wheel combination.
Full disclosure - I am a rather dedicated corner-carver and semi-serious autocrosser. I wouldn't drive around without a front sta-bar in place by choice, although I do have some experience with endlink bushings in such bad shape that the bar might as well not have been there. But even that's more a matter of personal preferences than on any difficulty in keeping the thing on the road and pointed in the right direction during driving that admittedly goes beyond 0.5g on a fairly frequent basis.
Actually, there are at least two opposing effects related to whether the front sta-bar is there or not. Losing the front roll stiffness is an effect in the "oversteer" direction. But it is at least partly balanced by what the greater amount of roll does to the camber on your front tires while you are cornering it hard - the outside front goes more positive, the inside front more negative, both of which mean that there's less front grip. That's your more-understeer effect.
Norm
#23
ORIGINAL: scramblr
What's holding up your radiator? The hoses? If so, that may not last long.
ORIGINAL: D_Gusler
Removed the two bolts on the end links to strut mounts.
Removed the four bolts on the sway bar brackets.
Removed entire swaybar.
And I'm done. No swaybar. Free mod. No problems.
#24
I'm stupid, never mind.[&:] I had taken all of mine off at the same time, so was thinking it's all one. Been awhile since I've looked at the front end. I'm usually in the middle and towards the back when under there. I'll go back to sleep now.
#26
ORIGINAL: D_Gusler
UUHhhhhh the radiator support.
ORIGINAL: scramblr
ORIGINAL: D_Gusler
Umm...I think you've completely missed the point of the mod. The idea is by removing the front swaybar, you can then swap out the radiator support for one that doesn't have to hold up to the stresses put onto it by the front swayabar. This new radiator support weighs about 35 pounds less than the stock one. 35 pounds off the front of the car on a drag launch is a huge advantage.
Just removing the swaybar will get you absolutely no where. I popped mine off one night to try and help the weight transfer and got absolutely nothing from it. My best ET's, trap speeds and short times were all identical to when it was on. No matter what I tried in the 7 runs that night, it was still the same..
#27
ORIGINAL: GT Bob
ORIGINAL: D_Gusler
ORIGINAL: scramblr
ORIGINAL: D_Gusler
#29
ORIGINAL: jwgroovin
John
John
