Steeda Sport Or Eibach Pro...Here We Go Again...
#41
RE: Steeda Sport Or Eibach Pro...Here We Go Again...
ORIGINAL: F1FanIn testing the Eibach Pro-Kit andSportline springs on a spring tester I found these Eibach springs are like a light switch in theirspring ratetransition from the very soft initial spring rate to the working spring rate. In essence there isnot aprogressive rate seen in the real world. The claims that they are progressive rate springsare correctbutthey are not working as a progressive rate spring when installed in the S197GT chassis! These springs are working as if they are a two piece coilover wth a main and tenderspring. Once the tender spring (the low inital spring rate), is compressed intocoil bind the main or working spring rate is in effect. On these cars the Eibach springs are not operating as progressive springs unless you are airborne or going through a dip in the road. You may as well buy a straight rate spring because when installed in an S197GTand driving on the road they are for all intents and purposes the same spring.
I kind of ended up here looking for answers to whether the Vogtland springs are linear, bi-linear, or progressive. Anybody know?
Norm
#43
Lowering Project Complete! Could not imagine doing this without an air impact wrench. I love this combo! Rides like it's on rails and no brake dive, etc.
Here's what I finally did:
[ul][*]Eibach Pro-Kit Springs ($140 shipped from a forum classified)[*]Steeda Pro Action Non-adjustable struts/shocks (about $400)[*]Steeda adjustable Pan Hard bar ($160) - Haven't measured yet to see if adjustment necessary[*]GT500 Upper Strut Mounts (like the GT but beefier and cheaper than Steeda, BMR, etc) 0 Knocking - Retail $80 - paid a little more because NO ONE has these in stock[*]New strut nuts from Ford[*]New Rubber Isolators (2) from Ford[*]One afternoon[/ul]
Steeda rear sway going on soon. With this array of parts, no spring compressor was needed as I had every part necessary. I had to find the schematic for the rubber isolators on line and take it to the Ford parts guy because they couldn't find it.
Anyway, very pleased!!!!!!!!!!!!!!!!!!!!!!!!!!! Thanks for all the votes that helped the decision.
Kevin
Kevin
09-24-2015 09:18 PM
