20" foose nitrous wheels rubbing wheel well
i have a 2007 vista blue mustang. i need help with determining the best tires size or i need to see if there is anything else to do besides buying 2 more front tires. i have 245/35 in the front and 285 in the back. the tires (front) are rubbing slightly on the wheel well anybody got any suggestions on what to do
RE: 20" foose nitrous wheels rubbing wheel well
First what mod's do you have on the car? Lowered? Camber bolts/plates? With the 245/35/20 tire there should be no rubbing at all. Do you have the right backspacing on the rims? What size rim are you running up front? Foose runs 245/40/20 tires on his cars.
Do you have the front end lowered? I have 255/45-18 in the front and I don't have any issues with rubbing. In fact I'm looking to lower a bit in the spring.
I have Foose Nitrous 20X9 with 255/35/20 (front) 20X10 with 295/30/20 Lowered with H&R 1.8" front drop and a 1.9" drop on Bilstein struts and Steeda HD strut mounts and have no issues what so ever. Something is not right because you definitely shouldn't be rubbing.
jwog666
12-27-2021 08:09 PM
mungodrums
09-28-2015 10:54 PM
