Rear Sway Bar Tak- off Bolts
I recently bought a GT Rear Anti-Sway bar takeoff from ninosports.com, however it did not come with any of the bolts neccesary for installation. i was wondering if anyone knew of where I could buy the bolts? I'm might take it to the dealer to install, because I don't have the time, do you think they would have them there?
RE: Rear Sway Bar Tak- off Bolts
hard to say if the dealer would have them in stock... if you're not worried about costs then the dealership is easiest. I got the part numbers and ordered the bolts off of fordparts.com (which was cheaper than the dealership route)... got them in 4 days. if you want the numbers just let me know...
Are these right? Because when I looked them up it said Front Suspension.
Rear - four (4) 8 x 16 bolts, nuts and washers for the ends connecting to the lower shock mounts. Two (2) 12 x 65 threaded end bolts, nuts and washers for the body mounts. Get Grade 8 only (they need to be strong and rust resistant so don't go cheap)
upper link bolt (2) w708737*s439
upper link nuts (2) w711029*s900
bracket nuts (4) w520213*s440
bracket bolts snap in style w707007*s439 (new #)
bracket if needed 4r3z*5486*aa
You said all you need is bolts, right?
I ordered these and got exactly all I needed to bolt on the rear sway bar. I got mine off of ebay and it came with everything except the bolts too
w708737-s439 (bolt, qty. 4)
w520213-s440 (nut, qty. 4)
w711368-s439 (bolt, qty. 4)
w520214-s440 (nut, qty. 2)
I ordered EXACTLY like this, even though it came with two extra bolts (the non c-clip ones), but I read somewhere that you have to order in this quantity - so I did, just to be safe. I actually took a bunch of pics while I stuck mine on, maybe if I get a chance I'll throw my little tutorial on here
musnicki
09-23-2015 07:11 AM
Dragonus18
09-09-2015 01:21 AM
