Should the bumpstops be snipped after lowering?
I just got done installing the Steeda Sports and after a test drive it is evident that the rear rubber bumpstops are making contact with the frame. I can only feal a slight thump under the harshest of bumpsand the rubber part is leaving a nice clean shiny contact spot. I was wondering if it was common practice to shave the tops off or not. I must admit these springs dropped the car more than I was expecting but I can't complain about the look. I remember snooping under a Shelby GT at a local dealer several months ago and I don't think the stops under it were different or modified in any way.
RE: Should the bumpstops be snipped after lowering?
I cut just the upper most "mushroomy" part. No negative problems to report because of it.
Just as a point of reference - with the Eibach-Pro you do not cut the bumpstops. The steeda sports must be a pretty big drop.
Well so far it seems I have one for and one against.... With regards to my drop, It dumped it 1.75 in the rear on the dot. The front was more in the 1.25 advertized ballpark. I don't know if it being a vert would make a difference. Ironicaly I did call Steeda and the response I got was "go ahead and take them off if they bother you. There are stops in the shock". Since it is my nature to question everything, the more I thought about it the crazier that sounded. I may consider trying a set of Roushes on the rear....
i have the bmr springs. 1.75 inches in the back but i also have the tokico d specs. I haven't hit the bumpstops yet in the week i've had it
Ok here are some pics (if they work). Is this similar to what you ended up with after the BMR's? If so, I can't understand how you aren't rubbing....
[IMG]local://upfiles/88377/5C90264E279E4E3D826774BF1A59FCAF.jpg[/IMG] [IMG]local://upfiles/88377/80329C02D4514CB39884121D664C2C0C.jpg[/IMG] |
I didn't cut mine. No problems with bottoming out.:)
Your another one who seems to have gotten by without any problems. I think I must not be praying to the right automotive god. When I try something thats worked without a hitch for everybody, it turns into a fiasco for me. Yay me! (sarcasm).Does yours look as low as mine?
i think mine actually sits a little lower, i'll get a pic tonight. Also I have the tokico D specs and If i remember correctly I think it said to keep the bumpstops, i have to check the instructions again when I get home
I cut mine in half! There's a huge bump I hit at 65-70 and I have no problems. Mine still hit the frame, but I can't really feel it. The only think I was worried about was the car bottoming out, meaning my exhaust scraping the road, but so far so good.
